Sanwa Supply Releases Multi-Function Wireless Mouse with Docking Station Supports 4K HDMI and USB 3.2
Sanwa Supply has introduced an innovative wireless mouse, the 400-MAWBT209BK (black and silver) and 400-MAWBT209BK2 (black and blue). These mice feature a unique USB Type-C RF/Bluetooth receiver that doubles as a USB dock with an HDMI output supporting up to 4K at 60Hz for monitors or projectors.
The dock includes a USB 3.2 Gen 3 Type-C port with 5 Gbps speed and PD support up to 100W (90W for peripherals), enabling connections to devices like SSDs and keyboards. The mouse offers five buttons, a Bluetooth/RF switch, an adjustable blue LED sensor (800, 1,200, and 1,600 DPI), and a range of 10 meters on non-magnetic surfaces. However, it might block adjacent ports on some laptops.
Sanwa Supply wireless mouse
Sanwa Supply Wireless Mouse Specifications:
  • Model: Sanwa Supply 400-MAWBT209BK (black/silver) and 400-MAWBT209BK2 (black/blue)
  • Wireless Connectivity: Bluetooth and 2.4GHz RF
  • Receiver/Dock Features:
    • USB Type-C 2.4GHz RF/Bluetooth receiver
    • HDMI output port supporting up to 4K@60Hz for monitors or projectors
    • USB 3.2 Gen 3 Type-C port with 5 Gbps speed
    • Power Delivery (PD) supports up to 100W (90W for peripherals)
  • Mouse Features:
    • 5 buttons with a Bluetooth/RF switch
    • Blue LED optical sensor with adjustable resolutions: 800, 1,200, and 1,600 DPI
    • Wireless range: 10 meters (non-magnetic surfaces), 2 meters (magnetic surfaces)
  • Potential Interference: USB 3.2 Gen 1 devices may affect 2.4GHz RF performance
  • Power Requirements: USB-C port with PD for dock functionality
  • Dimensions: 130 x 98 x 45mm (including package)
  • Weight: 0.160 Kg
This product is available in Japan for 5980 JPY ($39), and it is expected to support enhanced connectivity and dual-display setups, with potential availability in US stores of Amazon and AliExpress soon.
The company has also launched a 360-degree USB-C cable, designed to improve cable management with its fully rotatable connectors, allowing flexible orientation in any direction, marketed as a 540-degree cable due to dual-axis rotation, it supports power delivery up to 240W, making it suitable for charging high-power devices.
However, its data transfer speed is limited to USB 2.0 rates (480 Mbps), restricting its use for high-speed applications like USB4 or Thunderbolt storage devices. It is ideal for users prioritizing flexible cable orientation over high data transfer speeds.
Sanwa Supply 360-degree USB-C cable Specifications:
  • Data Transfer Speed: USB 2.0 (480 Mbps)
  • Misc:
    • Fully rotatable connectors allowing 360° rotation for improved cable management
    • Dual-axis rotation marketed as 540° capability
  • Power Delivery: Supports up to 240W
  • Lengths Available:
    • 1 meter
    • 1.8 meters
  • Limitations: Not suitable for high-speed applications like USB4 or Thunderbolt devices
Previously, we have not written anything like these products. However, we have covered Fischer LP360, which is almost similar to the 360-degree USB-C cable.
This product is available in one-meter and 1.8-meter lengths, priced at 2,580 JPY ($16.5) and 2,780 JPY ($17.8), the cable is currently sold only in Japan through Amazon Japan.
About Sayantan Nandy
view all posts by sayantan
