![SB Components releases Micro RP2040, a compact version of Raspberry Pi Pico SB Components releases Micro RP2040, a compact version of Raspberry Pi Pico](https://www.electronics-lab.com/wp-content/uploads/2023/07/SB-Components-Micro-RP2040.jpg)
The Micro RP2040 microcontroller board is a powerful development tool that includes most of the features of the Raspberry Pi Pico in a smaller and more compact form factor. The board is designed for hobbyists, students, and professionals, for a wide range of projects, from building robots and controlling smart home devices to experimenting with electronics.
Inside the Micro RP2040 is the RP2040 MCU, a dual-core Arm Cortex M0+ processor. With a clock speed of up to 133 MHz, this microcontroller can handle demanding tasks while keeping power consumption to a minimum. The RP2040 MCU also features a variety of built-in peripherals and interfaces, including USB, SPI, I2C, and UART, providing seamless connectivity options for your projects. You can find more detailed technical information about the RP2040 MCU in the datasheet available here.
Interestingly, the Micro RP2040 has 23 multifunction GPIO pins, which provide sufficient options for connecting sensors, displays, and other peripherals. These pins can be easily programmed to suit your specific project requirements, offering flexibility and expandability. Additionally, the board comes equipped with a USB Type-C connector, enabling straightforward connections to a computer or power source, making it incredibly convenient to use.
Specifications of Micro RP2040 microcontroller board:
- Microcontroller: Raspberry Pi RP2040 featuring dual-core Arm Cortex-M0+ processor, clocked at a frequency of 133 MHz
- Memory: 264kB of SRAM
- Storage: 2MB QSPI flash
- Interfaces: 23x multifunction GPIO pins
- Serial communication: PWM, I2C, SPI, and UART
- Power: USB Type-C port for the power source of 5V
- Button: Boot button can be used to enter bootloader mode when the board is powered on
- Software: C, C++, and MicroPython
- Dimensions: 25 x 24.95 mm
- Weight: Approximately 4 grams
When it comes to software support, the Micro RP2040 has you covered. It offers compatibility with a wide range of programming languages and development environments, ensuring that you can work with the tools you’re most comfortable with. Whether you prefer C, C++, or MicroPython, you can unleash your creativity and bring your ideas to life with ease.
The Micro RP2040 microcontroller board is available for purchase at an affordable price of $6.99 on Tindie, making it accessible to enthusiasts and professionals alike. With its compact size, powerful performance, and extensive connectivity options, it allows the user to explore the capabilities of RP2040 to create innovative IoT projects.
