![Seeed Studio XIAO ESP32C6 Dev Board Features a Compact Form Factor Seeed Studio XIAO ESP32C6 Dev Board Features a Compact Form Factor](https://www.electronics-lab.com/wp-content/uploads/2024/04/Seeed-Studio-XIAO-ESP32C6-Module-e1712077610352.jpg)
SeeedStudio has recently introduced XIAO ESP32C6 Dev Board with Wi-Fi 6/Bluetooth 5 and integrates Matter compatibility all built onto a thumb-size footprint.
After the initial release of the ESP32-C6 SoC last year we have seen boards like the SparkFun ESP32-C6 Thing Plus, the ePulse Feather C6, the Beetle ESP32-C6, and the FireBeetle 2 ESP32-C6 and many other built around this chip. but what makes this XIAO ESP32C6 special is its compact size, its ease of use, and its $5.20 price point.
The XIAO ESP32C6 features an onboard antenna with up to 80m BLE/Wi-Fi range and a connector for an external UFL antenna, offering flexible RF performance. It includes efficient power management with four modes, such as a deep sleep mode that uses only 15 µA, and supports lithium battery charge management for better energy use.
The XIAO ESP32C6 comes with a plethora of different features including secure boot, encryption, TEE, and cloud integration like AWS IoT, Arduino, Azure, and Google Cloud for IoT security. It matches the XIAO series form factor, offers 15x GPIO pins, and supports Arduino and ESP-IDF for flexible programming.
XIAO ESP32C6 Dev Board Specifications:
- ESP32-C6 SoC featuring:
- Single-core, 32-bit RISC-V microcontroller that can be clocked up to 160MHz
- 2.4GHz Wi-Fi 6 and Bluetooth 5.3/Bluetooth mesh connectivity
- Zigbee, Thread (802.15.4) support
- Memory:
- 320KB on-chip SRAM
- 256KB ROM
- Quad SPI flash
- Quad SPI PSRAM at up to 120MHz
- I/O interfaces include:
- 1x UART, 1x Low Power (LP) UART
- 1x I2C, 1x LP I2C, 1x SPI
- 11x GPIO with PWM capability, 7x ADC, 1x SDIO
- 1x User LED
- USB connectivity:
- 1x USB Type-C port
- Additional features:
- 1x Reset button, 1x Boot button
- 1x Status LED
- Operating temperature ranges from -40°C to 85°C
- Power options:
- 5V DC via USB Type-C
- 4.2V via Battery (BAT) connection
- Charging battery current of 350mA
- Compact size measuring 21 x 17.5mm
As of now, the XIAO ESP32C6 isn’t ready to ship and is available for backorder. You can place an order for $5.20 on the SeeedStudio Store, with shipments expected to begin on April 15, 2024.
