Seeed’s $799 Jetson SUB Mini PC Kit Combines Leetop’s A206 carrier board with a Xavier NX Module
Seeed Studio has launched a Jetson SUB Mini PC Kit designed for AI applications. The 130 mm x 120 mm x 50mm combines Xavier NX module with an A206 carrier board from Leetop.
The Jetson Xavier NX module delivers up to 21 TOPS and with 384 NVIDIA CUDA cores, 48 Tensor cores, Hexa-core Carmel 64-bit ARM CPUs, and two NVIDIA deep learning accelerators engines. The module is also said also offer 8GB LPDDR4x and 8-32GB eMMC 5.1, and preloaded with Nvidia’s Ubuntu-powered Jetpack SDK for tapping it’s AI capabilities.
The Leetop A206 carrier board on the other hand has a number of features including dual MIPI-CSI camera interfaces, a CANBus header, and 40-pin GPIO. The module also has a real-time clock with coin cell socket, a 15V/3A DC input, and a -25 to 80° operating temperature range.
The Jetson SUB mini PC also comes with a case, a heat sink, and a fan. There’s also a 512GB SSD, WiFi and BT, GbE, HDMI, DP, and 4x USB. The kit is ideal for high-performance compute and AI in embedded and edge systems. It is a choice platform for running modern neural networks in parallel and process high-resolution data from multiple sensors simultaneously.
Features and Specifications of the Jetson SUB mini PC include:
  • NVIDIA Jetson Xavier NX module with:
    • 6-core NVIDIA Carmel ARMv8.2 64-bit processor with 6 MB L2 + 4 MB L3 cache
    • NVIDIA Volta architecture with 384 NVIDIA CUDA cores and 48 Tensor cores
    • 2x NVDLA Engines, 7-Way VLIW Vision Processor
    • Multiple 4Kp60 encode, multiple 8Kp30/4Kp30 decode
    • 8 GB 128-bit LPDDR4x 51.2GB/s
    • 10 W | 15 W | 20 W
    • Up to 14 TOPS @ 10 W, Up to 21 TOPS @ 20W
  • 1x MicroSD slot
  • M.2 Key M socket fitted with a 128GB NVMe SSD
  • HDMI and DisplayPort
  • 2x MIPI CSI-2 D-PHY lanes compatible with Raspberry Pi HQ camera and RPi V2 camera
  • Gigabit Ethernet
  • WiFi & Bluetooth via M.2 Key-E card (included)
  • 4x USB 3.1 ports
  • USB 2.0 Micro-B
  • Header with GPIOs, I2C, I2S, SPI, UART
  • Power supply: 9 to 19V DC via power barrel jack
  • Dimensions: 130 mm x 120 mm x 50 mm
The mini PC kit comes with everything needed in terms of hardware and software already installed and set up. It is available for order at $799. Shipping already started on the 5th November this year. You will get it with an acrylic cover, an aluminum frame and two external antennas.
Other useful details on the Jetson SUB Mini PC Kit may be found on Seeed’s Jetson SUB and the A206 carrier board product pages.
About Emmanuel Odunlade
Hardware Design Engineer | #IoT Consultant |All things #ML | Entrepreneur | Serial Writer | Passionate about Innovation and technology as tools for solving problems in developing countries. Spare time is spent around writing and advocacy for the growth of the Maker/DIY Culture in Africa.
view all posts by emmanuel
