![SEGGER Releases Floating-Point Library to Support RISC-V SEGGER Releases Floating-Point Library to Support RISC-V](https://www.electronics-lab.com/wp-content/uploads/2020/02/SEGGER-PR76-RISC-V-FPL.jpg)
Comprehensive array of arithmetic functions, hand-coded & optimized in assembly language.
SEGGER‘s stand-alone Floating-Point Library has now been extended to include an assembly-optimized variant for RISC-V implementations. The library contains a complete set of high level mathematical functions that have been written in C, and uses advanced algorithms to maximize performance levels.
All of the functionality is fully verified, for both single and double precision operations. The RISC-V variant, like the existing variant for ARM, is optimized for both high-speed operation and small code size. The balance between size and speed can be configured at library build time.
The SEGGER Floating-Point Library for RISC-V is much smaller than equivalent open-source libraries currently available, while achieving up to 100 times the performance on some key operations. This library is also a part of the company’s Runtime Library, which is already included in the widely-used Embedded Studio platform.
For details on what makes a well thought-out runtime library different from a conventional runtime library, refer to the SEGGER Runtime Library webpage: https://www.segger.com/runtime-library
More information on the SEGGER Floating-Point Library can be accessed at: https://www.segger.com/floating-point-library
Detailed performance data is available at: https://wiki.segger.com/SEGGER_Floating-Point_Library
To fully experience it, download Embedded Studio (Windows, Linux and macOS) from: https://www.segger.com/downloads/embedded-studio
