![ON Semiconductor’s SECO-1KW-MCTRL-GEVB is a Compact Intelligent Power Module (IPM) Motor Driver ON Semiconductor’s SECO-1KW-MCTRL-GEVB is a Compact Intelligent Power Module (IPM) Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2020/01/SECO-1KW-MCTRL-GEVB.gif)
The SECO-1KW-MCTRL-GEVB is a complete reference design for three-phase motor drives, featuring the NFAQ1060L36T intelligent power module in a DIP/6 package. Rated for 230 Vac input and delivering up to 850W. All the necessary system blocks for a motor drive are part of the solution: EMC filtering and rectification stage, interleaved two-channel PFC, auxiliary power supplies, three-phase inverter and measurement and protection. The graphical user interface ensures an easy startup for evaluation purposes running voltage/frequency control. Furthermore, the system can accommodate additional control strategies.
- 850W Intelligent Power Module (IPM) three-phase motor driver
- VIN: 230 Vac,rms ± 15% (single-phase)
- IOUT: Irms 10 ARMS per phase
- Compatible with three-phase motors: PMSM, BLDC or ACIM
- DIP/6 IPM NFAQ1060L36T, three-phase/10A with integrated gate drivers
- Cross-conduction, overcurrent and thermal protection embedded in DIP/6 module
- Plug-in connector interface for MCU cards (Arduino DUE footprint)
- Voltage/frequency control strategy implemented
- NCS2250SN2T3G: Push Pull Output Comparator implemented in Itrip protection system
more information: www.onsemi.cn
Login
