![ShielDIY Do-It-Yourself Custom Shielding Cabinets ShielDIY Do-It-Yourself Custom Shielding Cabinets](https://www.electronics-lab.com/wp-content/uploads/2020/07/360002_Würth_Elektronik_RF_IF_and_RFID_DigiKey.png)
Würth Elektronik has created a do-it-yourself custom shielding cabinet kit, the ShielDIY. The ShielDIY kit is a fast prototyping solution for board level shielding cabinets. The kit is made up of nickel silver sheet with a thickness of 0.2 mm. The sheets feature lines carved every 5 mm for easy bending and cutting. To build a prototype, cut along the carved lines before bending to obtain the desired shape.
- Do-it-yourself shielding cabinet; users can create a custom cabinet with this kit
- Shape board-level shielding
- Foldable and cuttable with carved lines every 5 mm
- Material is nickel silver with the same performance as the tinplated steel used in the standard cabinets
- Useful for fast prototyping
Applications
- Preventing EMI radiation from PCB and keeping sensitivity low
- RF output stages
- RF input and amplifier stages
- Oscillators
- EMC-sensitive parts in plastic cases
more information: www.we-online.com
Login
