![Siglent SDG6000X Series Arbitrary waveform generator review, teardown and experiments Siglent SDG6000X Series Arbitrary waveform generator review, teardown and experiments](https://www.electronics-lab.com/wp-content/uploads/2018/06/siglent-sdg6000x-series-arbitrar.jpg)
In this episode Shahriar takes a close look at the newly released Siglent SDG6000X Series Pulse / Arbitrary Waveform Generator. SDG6000X is a series of dual-channel Pulse/ Arbitrary Waveform Generators that feature up to 500MHz output frequency, a maximum sample rate of 2.4GSa/s and 16-bit vertical resolution when used as a function generator. The particular reviewed model is the SDG6052X which is the top-end model. The full teardown of the unit reveals the internal architecture of the instrument, DAC / FPGA interconnect as well as the output amplifier structure. Although the limitations of the FPGA prevents the instrument to operate at full 2.5GSa/s in arb-mode, the instrument is capable of providing complex modulation up to the full 500MHz signal bandwidth.
Siglent SDG6000X Series Arbitrary waveform generator review, teardown and experiments – [Link]
