![Siglent SDM3055 5.5 Digit Bench Multimeter Review Siglent SDM3055 5.5 Digit Bench Multimeter Review](https://www.electronics-lab.com/wp-content/uploads/2015/09/siglent-sdm3055-5-5-digit-bench.jpg)
SIGLENT’s SDM3055 series is a dual display digital desktop multimeter. The SDM3055 provides a rich and powerful feature set at an excellent price. This DMM family is well suited for production testing, R&D and certification work, as well as any place where an accurate and powerful full-function DMM is needed. In the SDM3055’s design and layout, great emphasis was given on both front-panel and computer-based control of the instrument. Equipped with a 4.3 inch TFT-LCD true color LCD screen, its display resolution is up to 480 * 272. It can not only display numerical readings, but also supports histograms, trend charts, bar charts and statistics, in addition to the built-in arithmetic functions. Even when using the front-panel menu, the user can display the most important analysis results of the accumulation of time and data. This eliminates the process of drawing and statistics, and the measurement is accurate and reliable. The SIGLENT SDM3055 has a powerful testing engine, measuring speed up to 150rdgs / s, 1Gb Nand total memory capacity, mass storage instrument settings, historical data, and external U disk external storage. The SDM3055 interfaces include USB Device, USB Host, LAN and GPIB (SDM3055A). It can support VXI11, USBTMC remote control as well as interconnection with National Instruments’ LabVIEW. A SCPI command programming manual is also provided in support of remote control operation programming.It is compatible with mainstream multimeter command sets and uses the compatible language with SCPI for transmission and control.
Siglent SDM3055 5.5 Digit Bench Multimeter Review – [Link]
