![Silicon Photomultiplier is utilized for ultra-sensitive precision measurements of single photons Silicon Photomultiplier is utilized for ultra-sensitive precision measurements of single photons](https://www.electronics-lab.com/wp-content/uploads/2023/05/191648616.png)
Broadcom AFBR-S4N66P014M NUV-MT Silicon Photomultiplier is utilized for ultra-sensitive precision measurements of single photons. The single-channel SiPM is based on the NUV-MT technology, which integrates improved photo-detection efficiency (PDE) with a decreased dark count rate and crosstalk compared to the NUV-HD technology. The device has a SPAD pitch of 40µm. By tiling multiple Broadcom AFBRS4N66P014M SiPMs, larger areas can be covered.
The Broadcom AFBR-S4N44P044M array encapsulates an epoxy clear mold compound for excellent mechanical stability and robustness. The epoxy is highly transparent down to UV wavelengths, resulting in a broad response in the visible light spectrum with high sensitivity toward the blue and near UV region.
The device is well suited for detecting low-level pulsed light sources, especially Cherenkov or scintillation light from the most common organic (plastic) and inorganic scintillator materials (for example, LSO, LYSO, BGO, NaI, CsI, BaF, or LaBr3).
- 2×2 SiPM array
- Array size of 8.26mm × 8.26mm
- High PDE (63% at 420nm)
- Excellent SPTR and CRT
- Excellent uniformity of breakdown voltage
- Excellent uniformity of gain
- 4-side tileable, with high fill factors
- 40μm cell pitch
- Highly transparent epoxy protection layer
- Operating temperature range from -20°C to +50°C
- RoHS, CFM, and REACH compliant
more information: https://www.broadcom.com/products/motion-control-encoders/incremental-encoders/reflective-encoders/aedr-9930
