![Simple Pressure Sensor Amplifier & Over Pressure Switch Simple Pressure Sensor Amplifier & Over Pressure Switch](https://www.electronics-lab.com/wp-content/uploads/2017/04/photo.png)
The pressure sensor amplifier built using LM358 op-amp and MPXM2051GS pressure sensor from NXP semiconductor. The circuit provides 4V output for full scale pressure input 0-7.5PSI. One op-amp is used as amplifier and 2nd op-amp is used as comparator to provide an output at set value that can be used as over pressure switch to control a pump or solenoid. This is a low cost general-purpose circuit for those applications where +/-3% performance is acceptable. Multi turn potentiometers are provided for Offset, span adjust & over/under Pressure set point to control output devices like solid state relay, Pump, and solenoid.
- Supply 12V DC
- Pressure Sensor range 0-7.5PSI
- Output 0-4V (Approx.)
- PR1 Multi-Turn Potentiometer Offset
- PR2 Multi-Turn Potentiometer Span Set
- PR3 Multi-Turn Potentiometer Comparator (Switch) output Set
- D1 Power LED
- CN1 4 Header Connector Outputs & Supply Input
Simple Pressure Sensor Amplifier & Over Pressure Switch – [Link]
Login
