![simpleFE – A simple mixed signal front-end simpleFE – A simple mixed signal front-end](https://www.electronics-lab.com/wp-content/uploads/2019/11/simplefe-proto-02_jpg_project-main.jpg)
simpleFE is a low cost, fully open-source, mixed-signal front-end. Designed primarily to carry out analog-to-digital and digital-to-analog conversion, simpleFE includes plenty of IO and allows you to create your own signal processing system more quickly, more easily, and more cost-effectively.
Features & Specifications
- ADC: 8-bit, two channels, up to 7.5 Msps (I and Q)
- DAC: 10-bit, two channels up to 7.5 Msps (I or Q) or 5 Msps (I and Q)
- USB: High speed interface (USB 2.0)
- GPIO: 16 pins
- DAC Output: 10-bit, four pins
- SPI: One interface
- I²C: One interface
- Antenna Connectors:
- Two U.fl analog output (50 Ohm output impedance)
- Two U.fl analog input (high impedance)
Components
- USB: EZ-USB FX2LP (CY7c68013A)
- FPGA: ICE40HX1K
- Front-end: MAX5863
- Software: GNURadio, gr-simplefe, libsimplefe C library
The project will launch soon on www.crowdsupply.com
Login
