![Single IC can produce isolated or non-isolated ±12V outputs Single IC can produce isolated or non-isolated ±12V outputs](https://www.electronics-lab.com/wp-content/uploads/2020/02/LT8315-e1581586441759.jpg)
Linear Technology’s 560 VIN micropower no-opto isolated flyback converter with 630 V / 300 mA switch
Linear Tech’s LT8315 high voltage flyback converter with integrated 630 V / 300 mA switch needs no opto-isolator for regulation. It samples the output voltage from the isolated flyback waveform appearing across a third winding on the transformer. Its quasi-resonant boundary mode operation improves load regulation, reduces transformer size, and maintains high efficiency. At start-up, the LT8315 charges its INTVCC capacitor via a current source attached to the DRAIN pin. The current source turns off and the device draws its power from a third winding on the transformer during normal operation. It operates from a wide range of input supply voltages and can deliver up to 15 W of power. The LT8315 is available in a thermally enhanced 20-pin TSSOP package with four pins removed for high-voltage spacing.
![](https://www.electronics-lab.com/wp-content/uploads/2020/02/270471-fig-01v5.jpg)
- Wide input voltage range: 18 V to 560 V
- 630 V / 300 mA integrated power switch
- No opto-isolator required for regulation
- Quasi-resonant boundary mode operation
- Constant-current and constant-voltage regulation
- Low-ripple light load Burst Mode® operation
- Low quiescent current: 70 μA
- Programmable current limit and soft-start
- TSSOP package with high-voltage spacing
more information: www.analog.com
