Slim Yet Mighty Digital Signage Player for Immersive 4K Visuals
1.071
IBASE Technology Inc., a leader in digital signage and smart retail computing solutions, debuts the SI-212-N, a compact digital signage player built to deliver top performance in entry-level applications. Designed for vibrant 4K displays across retail, public spaces, and transportation hubs, the SI-212-N is powered by the latest Intel® Atom® x7000E Series, N-series, and Core™ i3-N305 processors (formerly Alder Lake-N), providing the perfect blend of efficiency and power for dynamic digital signage.
The SI-212-N stands out with its dual HDMI 2.0 outputs, each capable of driving independent 4K displays, creating immersive and synchronized visuals. The fanless design ensures quiet, dust-free operation, making it ideal for 24/7 deployment. With built-in CEC (Consumer Electronics Control) and hardware EDID emulation functions, the device allows seamless display management through software settings, making it easier to set up and optimize for different display requirements.
SI-212-N FEATURES:
  • iSMART intelligent energy-saving technology – enables power on/off scheduling and power resume functions
  • Intel® Atom® x7000E Series / N-series / Core™ i3-N305 processors
  • 1x DDR5-5600 SO-DIMM, dual channel, Max. 32GB
  • 2x HDMI 2.0 with independent audio output
  • Built-in CEC and hardware EDID emulation functions with software setting mode
  • Supports PDPC (Peripheral Device Power Control) function
  • Supports OOB function via I210IT LAN port (optional)
  • 1x M.2 E-Key (2230) for WiFi, Bluetooth options
  • 1x M.2 M-Key (2280) for storage
  • TPM 2.0 and watchdog timer
  • Industrial-grade robust and compact fanless design
Versatility is a core strength of the SI-212-N. It features up to 32GB DDR5-5600 memory for fast data processing, and an M.2 E-key (2230) slot to enable Wi-Fi and Bluetooth connectivity. The M.2 M-key (2280) slot supports NVMe SSDs for high-speed data access, enhancing the playback quality of resource-heavy signage content. For secure and stable operations, the device integrates TPM 2.0 and a watchdog timer. Additionally, the Out-of-Band (OOB) management function via the I210IT LAN port facilitates remote troubleshooting, enhancing operational reliability. It also supports Peripheral Device Power Control (PDPC), optimizing power efficiency for connected peripherals.
Measuring just 217mm x 123mm x 22.5mm, the SI-212-N is both robust and space-saving, operating effectively in harsh environments. Compatible with Windows 11 IoT and Linux Ubuntu 64-bit, this compact powerhouse meets diverse application needs in various indoor environments. Its durable aluminum chassis ensures long-lasting performance, making it a solid choice for the digital signage market.
