![Small host-based module with Wi-Fi 5 and Bluetooth low energy 5 Small host-based module with Wi-Fi 5 and Bluetooth low energy 5](https://www.electronics-lab.com/wp-content/uploads/2019/11/Multiradio-Module-from-u-blox-to-Target-Automotive-and-Industrial-Applications-large_637104231717666557.jpg)
u-blox has introduced the JODY-W2 multiradio module, a feature-rich and compact wireless module for automotive applications. by Ally Winning @ eenewsembedded.com
Measuring only a 13.8mm x 19.8mm to address the space constraints that car manufacturers face, the module can operate in temperatures from -40ºC to 105ºC. The module is also well suited for industrial applications.
The robust module uses the latest AEC-Q100 qualified wireless SoC technology. A variant is available for industrial control and monitoring applications without AEC-Q100 certification. It offers Wi-Fi 5 (802.11ac), covering both the 2.4GHz and 5GHz frequency channels in addition to WPA3-compliant security mechanisms. It also has Bluetooth 5 capabilities, with both Bluetooth Classic and Bluetooth low energy. Separate antennas are used for Bluetooth and Wi-Fi.
Specifications
- Dual band Wi‑Fi 2.4 GHz and 5 GHz 802.11a/b/g/n/ac
- Dual‑mode Bluetooth 5 (Bluetooth BR/EDR and Low Energy)
- Supports operation at 105 ° C
- Simultaneous access point (AP), station (STA), or Wi‑Fi Direct (P2P)
- Optimized for parallel operation of Wi‑Fi and Bluetooth
JODY-W2 modules are able to provide an access point for connection with up to 8 devices with high enough enough bandwidth for video streaming through several devices at once. It can support parallel transportation of Wi-Fi and Bluetooth signals, and can simultaneously act as an access point and as a station, or conduct peer-to-peer communication.
The JODY-W2 modules are manufactured to have the same form factor as the u-blox JODY-W1 series, making it easier to upgrade existing designs.
More information: https://www.u-blox.com/en/product/jody-w2-ser
