![Smart Plug Reference Design – MP161 Non-Isolated Buck Regulator with ESP8266 Smart Plug Reference Design – MP161 Non-Isolated Buck Regulator with ESP8266](https://www.electronics-lab.com/wp-content/uploads/2020/02/Picture1_1.png)
Nowadays everything is connected. So why not also connect the wall plugs? Monolithic Power Systems presents a reference design with the MP161 part that will allow customers to join the IoT market. This is a two boards design, one for the dc-dc converter and the relay and the other for the Wi-Fi module. The configuration is designed to fit into a wall-plug.
This reference design is based on the MP161 which includes a 700V switching regulator, a low-dropout linear regulator and two channel relay drivers. The design includes Wi-Fi 802.11 b/g/n (HT20) protocol and 35.4mW active input power under stand-by operation.
![](https://www.electronics-lab.com/wp-content/uploads/2020/02/Smart-PLug-block-diagram.jpg)
The relay driver in the MP161 includes 2Ω on-state resistance, rail voltage up to 30V, integrated freewheeling diode, and a nominal off driver. The integrated LDO handles up to 30V input voltage; it delivers a fixed output of either 3.3V or 5V and includes over-temperature protection
Summary of MP161 Features
- Integrated 700V MOSFET and current source
- Constant voltage regulation with internal loop compensation
- Optimized light-load efficiency by frequency modulation
- Standby mode
- Anti-audible noise operation by peak current modulation
- Adjustable or fixed 12V Output
- Low operating current
- Integrated protection functions
- Over-Temperature Protection (OTP)
- Short-Circuit Protection (SCP)
- Over-Load Protection (OLP)
- Over-Voltage Protection (OVP)
