![SODAQ ONE board – GPS + LoRa + Solar charger SODAQ ONE board – GPS + LoRa + Solar charger](https://www.electronics-lab.com/wp-content/uploads/2018/02/sodaq-one-eu-rn2483-v3-1024x736.jpg)
This is the third generation of our succesful SODAQ ONE board. It is equipped with a solar charge controller and runs on a LiPo or a permanent battery. It has the Ublox Eva 8M GPS module which is not only miniature but with it’s assisted GPS feature it can get a fix within seconds. We’ve now added an extremely low power Accelerometer/Magnetometer. This gives the board a nifty feature where it can stay in (deep) sleep mode until it moves. An essential feature for developing low power devices.
Let’s imagine you want to develop a bicycle tracker using the SODAQ ONE. You would like to track the position of the bike, but only when it has moved. This is possible if you keep the device in deep sleep until it detects motion. If the motion continues for a while, the bicycle may have changed position so only then the GPS will switch on to get a new reading and send this location over the LoRa network. Efficient right? This system will allow you make most efficient use of your battery capacity by only using the GPS when really needed, essentially increasing the battery life of your system.
SODAQ ONE board – GPS + Solar charger board – [Link]
