![SoM based on Microchip’s low-power PolarFire RISC-V SoC FPGA SoM based on Microchip’s low-power PolarFire RISC-V SoC FPGA](https://www.electronics-lab.com/wp-content/uploads/2020/03/2020-01-29-eenews-jh-aries.jpg)
The M100PFS is based on the PolarFire SoC FPGA architecture by Microchip and combines high-performance 64-bit RISC-V cores with outstanding FPGA technology. The platform integrates a hardened real-time, Linux capable, RISC-V-based MPU subsystem on the mid-range PolarFire FPGA family, bringing low power consumption, thermal efficiency and defence grade security to embedded systems.
The RISC-V CPU micro-architecture implementation is a simple 5 stage, single issue, in-order pipeline that doesn’t suffer from the Meltdown and Spectre exploits found in common out-of-order machines. All five CPU cores are coherent with the memory subsystem allowing a versatile mix of deterministic real time systems and Linux in a single multi-core CPU cluster.
Features:
- Microsemi PolarFire SoC FPGA
- MPFS025T
23KLE, 68 math blocks, 4x SERDES 12.5Gbit/s, 2x PCIe root port/end point - MPFS095T, available on request
93KLE, 292 math blocks, 4x SERDES 12.5Gbit/s, 2x PCIe root port/end point - MPFS160T, available on request
161KLE, 498 math blocks, 8x SERDES 12.5Gbit/s, 2x PCIe root port/end point - MPFS250T
254KLE, 784 math blocks, 16x SERDES 12.5Gbit/s, 2x PCIe root port/end point
- MPFS025T
- Quad 64-bit RV64GC cores, 667 MHz
- 64-bit RV64IMAC monitor core, 667 MHz
- Processor I/O
- 2x Gigabit Ethernet
- 1x USB 2.0 OTG
- 1x MMC 5.1 SD/SDIO
- 2x CAN 2.0 A and B
- Execute in place Quad SPI flash controller
- 5x multi-mode UARTs
- 2x SPI, 2 I2C
- RTC, GPIO
- 5x watchdog timers
- timers
- Processor to FPGA Interconnect
- 2 64-bit AXI4 processor-to-fabric interfaces
- 3 64-bit AXI4 fabric-to-processor interfaces
- 1 32-bit APB processor-to-fabric interface
- 1/2/4 GByte LPDDR4 RAM dedicated to the HMS
- 1/2/4 GByte LPDDR4 RAM dedicated to the FPGA
- 32 Mbit NOR Flash
- 4 – 64 GByte eMMC memory
- Clock distribution
- default configuration:
- Gigabit Ethernet
- UART
- CAN
- SPI
- I²C
- USB
- single 3,3V supply
- size 74mmx42mm
- 2 x Samtec QSH-090-01-F-D-A board-to-board interconnect
Schedule & Availability
The M100PFS are currently under development, first boards are to be expected appr. in Q3/2020
More information may be found in the Aries Embedded announcement and product page.
