![Sound to light effect Sound to light effect](https://www.electronics-lab.com/wp-content/uploads/2015/11/J0091.jpg)
Audio Dancing LED project is a fun filled project which generates a LED dancing sequence depending on the audio level it senses. This project is based on one of the VU Meter IC LB1403 or CA1403
Specifications
- Power supply input 6 to 9 VDC
- Output 5 LED’s
- Onboard preset to adjust audio level to the IC
- Onboard microphone capsule with Preamp
- Terminal pins for connecting power supply input
- Four mounting holes of 3.2 mm each
- PCB dimensions 39 mm x 67 mm
Sound to Light Effect – [Link]
Login
