![SparkFun Pro Micro – ESP32-C3 Features a Qwiic Connector SparkFun Pro Micro – ESP32-C3 Features a Qwiic Connector](https://www.electronics-lab.com/wp-content/uploads/2024/01/DEV-23484-Pro-Micro-ESP32-C3-Feature-e1706426741272.jpg)
SparkFun has recently announced the “SparkFun Pro Micro – ESP32-C3” board, an ESP32-C3-based development board featuring SparkFun’s Qwiic Connect System. This compact board includes Wi-Fi, Bluetooth, GPIO, SPI, UART, I2C, I2S, and all the necessary hardware required for advanced IoT and embedded applications.
Previously we have covered many ESP32-C3-based development boards like the Wemos Lolin C3 Pico, Olimex ESP32-C3-DevKit-LiPo, Lilygo T-Zigbee with ESP32-C3, Adafruit QT Py ESP32-C3 and many other ESP32-C3 powered development board, feel free to check those out if you are interested in the ESP32-C3 module.
The Pro Micro ESP32-C3 features a RISC-V core, 400KB of SRAM, and runs at 160MHz, all integrated into a compact 1.3in. x 0.7in. board. It features an easy Qwiic connection, built-in WiFi, Bluetooth 5, and 22 GPIOs, supporting ADC, SPI, UART, and I2C, perfect for a wide range of projects.
SparkFun Pro Micro – ESP32-C3 Board Specifications:
- CPU and On Chip Memory
- ESP32-C3FH4 embedded,32-bit RISC-V single-core processor, up to 160MHz
- 384 KB ROM
- 400 KB SRAM (16 KB for cache)
- 8 KB SRAM in RTC
- 4 MB flash in a chip package
- WiFi
- 802.11b/g/n
- Center frequency range of operating channel:2412~2484 MHz
- Supports 20 MHz, 40 MHz bandwidth in 2.4 GHz band
- 1T1R mode with data rate up to 150 Mbps
- Wi-Fi Multimedia (WMM)
- TX/RX A-MPDU, TX/RX A-MSDU
- Immediate Block ACK
- Fragmentation and defragmentation
- Bluetooth
- Bluetooth LE: Bluetooth 5, Bluetooth mesh
- Speed: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
- Channel selection algorithm #2
- Internal co-existence mechanism between Wi-Fiand Bluetooth to share the same antenna
- Peripherals
- GPIO, SPI, UART, I2C, I2S, remote control peripheral, LED PWM controller, general DMA controller, TWAI®controller (compatible with ISO11898-1, i.e. CAN Specification 2.0), USBSerial/JTAG controller, temperature sensor, SARADC, general-purpose timers, watchdog timers
- Integrated Components on Module
- 40 MHz crystal oscillator
- Antenna Options
- On-board PCB antenna (ESP32-C3-MINI-1)
- Operating Conditions
- Operating voltage/Power supply: 3.0 ~ 3.6 V
- Operating ambient temperature: –40 ~ 85 °C
- 1x Vertical Qwiic Connector
The SparkFun Pro Micro ESP32-C3 supports Espressif’s ESP-IDF and Arduino IDE, offering a wealth of libraries and community support for diverse projects. Ideal for wearables, and IoT devices.
For the Pro Micro ESP32-C3, SparkFun offers resources, all accessible through their GitHub repository. This includes the schematic, Eagle files, board dimensions, a hookup guide, the ESP32-C3FN4 datasheet, a reference manual, information on the Qwiic system, and much more.
The product is available for purchase at $9.95 on the SparkFun store.
