![SparkFun Qwiic Haptic Driver – DA7280 SparkFun Qwiic Haptic Driver – DA7280](https://www.electronics-lab.com/wp-content/uploads/2021/05/17590-SparkFun_Qwiic_Haptic_Driver_-_DA7280-01-e1621876552933.jpg)
SparkFun Qwiic Haptic Driver – DA7280 includes a Linear Resonant Actuator (LRA) vibration motor and Dialog Semiconductor’s DA7280 motor driver IC for applications that require haptic feedback. Control the vibration motor with the DA7280 via I2C, PWM, or a combination of three general-purpose input pins. It uses the handy Qwiic system, so no soldering is required. Simply connect it to the rest of a system. Included are 0.1″-spaced PTH pads in case a breadboard is preferred to access the driver’s I2C, power, interrupt, and general-purpose input pins on the edge of the board. This board is ideal for projects that require a physical indicator whenever an event is triggered.
- 2x Qwiic connection ports
- 1x built-in LRA vibration motor
more information: https://www.sparkfun.com/products/17590
Login
