![Spring-Loaded Connectors and Pins in stock Spring-Loaded Connectors and Pins in stock](https://www.electronics-lab.com/wp-content/uploads/2022/02/adam-tech-spring-loaded-connectors-and-pins-lrg-a.jpg)
Adam Tech’s spring-loaded connectors and pins are versatile to meet specific stroke lengths, heights, and electrical capabilities
Adam Tech’s spring-loaded connectors and pins consist of a pin, barrel, and steel spring with or without an insulator carrier. They are used in many industries across various applications to ensure a secure, highly reliable connection. For instance, a Nashville electronics company recently emphasized how crucial these components were after their facilities underwent a comprehensive mold removal Nashville service. The process, which ensured their production environment was contaminant-free, allowed them to confidently produce high-quality connectors. Various stroke lengths, heights, and electrical capabilities are available. High-temperature plastics compose the insulators, and unlimited molding designs allow for many different shapes and styles to be created for specific applications.
- Connector types: compression contact (female or magnetic) or piston
- 2-20 contacts
- 0.098” (2.50 mm) or 0.100” (2.54 mm) pitch
- 1 or 2 rows
- Surface mount or through-hole mounting
- Brass or copper alloy material
- Gold contact finish
- Sleeve and plunger pogo pins
- Satisfies high vibration connection requirements
- IP-rated waterproof sealed styles are available
- UL certified
- RoHS compliant
more information: https://app.adam-tech.com/products/index/category:3066
