![Stereo volume and balance control with Rotary Encoder using MAX5440 Stereo volume and balance control with Rotary Encoder using MAX5440](https://www.electronics-lab.com/wp-content/uploads/2019/12/001-e1576058617802.jpg)
The project described here is a compact stereo volume and balance control with rotary encoder. It provides 32 log potentiometer steps with buffered wiper output. The project can easily replace mechanical potentiometer. 5 LEDs indicate the volume level or balance settings , depending on the status of the mode indicator D1 LED. The MAX5440 includes debounced pushbutton inputs for mute and mode. The mute input allows a single pushbutton to change between volume control and the -90dB (typ) mute setting. The mode input toggles between volume and balance control. A click-and-pop suppression feature minimizes the audible noise generated by wiper transitions.
Stereo volume and balance control with Rotary Encoder using MAX5440 – [Link]
Login
