![STINGER96 – 96Boards IoT Edition Baseboard STINGER96 – 96Boards IoT Edition Baseboard](https://www.electronics-lab.com/wp-content/uploads/2020/05/STINGER96-–-Shiratech-Solutions.png)
Shiratech launches its NEW 96Boards IoT solution based on ST STM32MP157 MCU + QUECTEL BG9IoT6 NB-IOT modem.
The Board is 96Boards IoT Edition Extended Compatible (IE extended). Full support for 96Boards IoT Edition (IE) Low Speed expansion connector.
STM32MP157 Main features
- 32-bit dual-core Arm® Cortex®-A7
- Up to 650 MHz (Up to 4158 CoreMark®)
- L1 32 Kbyte I / 32 Kbyte D for each core
- 256 Kbyte unified level 2 cache
- Arm® NEON™ and Arm® TrustZone®
- 32-bit Arm® Cortex®-M4 with FPU/MPU
- Up to 200 MHz (Up to 673 CoreMark®)
MEMORY
- External DDR memory – DDR3 – 256M X 32Bit
- 708 Kbyte of internal SRAM: 256 KB of AXI SYSRAM + 384 KB of AHB SRAM + 64 KB of AHB SRAM in backup domain and 4 KB of SRAM in backup domain
- NAND Flash – SLC NAND Flash Parallel 1.8V 8Gbit 1G x 8Bit 63-Pin VFBGA
SECURITY
- Secure boot, TrustZone® IPs, active tamper
CONNECTIVITY
- On Board Camera DSMI 12Bit interface
- JTAG interface – ST LINK JTAG Interface
- 1 x 10/100/1000 Ethernet based on KSZ9031RNX Microchip Phy
- 2 x USB2 interfaces (One for External Connector, One for BG96 Modem)
- 1 x Uart (Via FTDI & Micro USB interface)
- 1 x SD interface
- Full 96 IOT LS connector Interface (1.8V interface)
- 2 x UART
- 2 x I2C
- GPIO Support A-L
- 1 x SPI
- 1 x PCM
BG96 (NBIOT Modem) – Interface
- 2 x Control lines
- 1 x USB Interface
BG96 Main features
CORE
- Quectel BG96 LTE CAT-M1 Modem
- Modem speed 300Kbps DL / 375Kbps UL
- Built in GPS
- Industrial grade
- Low Power
- Compatible with 96Boards CE and EE boards
- I2C, UART, GPIO for modem operation
POWER
- Input power 5V
MECHANICAL
- 96Boards IOT Edition Form Factor –
- Standard SMARC form factor: 85mmx 54mm
Login
