![STM32WLEx 32-Bit Wireless Long-Range MCUs STM32WLEx 32-Bit Wireless Long-Range MCUs](https://www.electronics-lab.com/wp-content/uploads/2021/01/STMicroelectronicsSTM32WL5xandSTM32WLEx.jpg)
STMicroelectronics’ long-range wireless and ultra-low-power devices embed a powerful ultra-low-power LPWAN-compliant radio solution
STMicroelectronics’ STM32WLE5/E4xx long-range wireless and ultra-low-power devices embed a powerful ultra-low-power LPWAN-compliant radio solution, enabling the LoRa® (available in STM32WLx5xx only), (G)FSK, (G)MSK, and BPSK modulations. These MCUs are compatible with standardized or proprietary protocols such as LoRaWAN®, Sigfox, W-MBUS, and more (fully open wireless system on chip).
Key features
- Arm® Cortex®-M4 CPU up to 48 MHz
- Up to 256 KB Flash and 64 KB SRAM
- Sub-GHz radio – multi-modulations: LoRa, (G)FSK, (G)MSK, BPSK
- Peripherals: 3 x I²C, 2 x USART, 1 x LP-UART, 2 x SP
Additional features
Radio
- Frequency range: 150…960 MHz
- Modulation: LoRa®, (G)FSK, (G)MSK, and BPSK
- RX sensitivity:
- -123 dBm for 2-FSK (at 1.2 Kbit/s)
- -148 dBm for LoRa® (at 10.4 kHz, spreading factor 12)
- Transmitter high output power, programmable up to +22 dBm
- Transmitter low output power, programmable up to +15 dBm
- Compliant with the following radio frequency regulations:
- ETSI EN 300 220, EN 300 113, EN 301 166, FCC CFR 47 Part 15, 24, 90, 101, and the Japanese ARIB STD-T30, T-67, T-108
- Compatible with standardized or proprietary protocols such as LoRaWAN®, Sigfox™, W-MBus, and more (fully open wireless system-on-chip)
Ultra-low-power platform
- 1.8…3.6 V power supply
- -40…+105 °C temperature range
- Shutdown mode: 31 nA (VDD = 3 V)
- Standby (+ RTC) mode: 360 nA (VDD = 3 V)
- Stop2 (+ RTC) mode: 1.07 µA (VDD = 3 V)
- Active-mode MCU: < 72 µA/MHz (CoreMark®)
- Active-mode RX: 4.82 mA
- Active-mode TX: 15 mA at 10 dBm and 87 mA at 20 dBm (LoRa® 125 kHz) Core
- 32-bit Arm® Cortex®-M4 CPU:
- Adaptive real-time accelerator (ART Accelerator) allowing 0-wait-state execution from Flash memory
- Frequency up to 48 MHz
- MPU and DSP instructions
- 1.25 DMIPS/MHz (Dhrystone 2.1)
- 32-bit Arm® Cortex®-M0+ CPU (for STM32WLEx series only)
- MPU instructions
- 0.95 DMIPS/MHz (Dhrystone 2.1)
more information: https://www.st.com/en/microcontrollers-microprocessors/stm32wlex.html
Login
