![STMicroelectronics TSZ182 and TSZ182H zero drift 5V CMOS Op-Amps STMicroelectronics TSZ182 and TSZ182H zero drift 5V CMOS Op-Amps](https://www.electronics-lab.com/wp-content/uploads/2020/11/STMicroelectronicsTSZ182andTSZ182H.jpg)
The TSZ181, TSZ182 are single and dual operational amplifiers featuring very low offset voltages with virtually zero drift versus temperature changes.
The TSZ181, TSZ182 are single and dual operational amplifiers featuring very low offset voltages with virtually zero drift versus temperature changes. They offer rail-to-rail input and output, excellent speed/power consumption ratio, and 3 MHz gain-bandwidth product, while consuming just 1 mA at 5 V. The device also features an ultra-low input bias current. These features make the TSZ18x ideal for high-accuracy high-bandwidth sensor interfaces.
Key features
- Very high accuracy and stability
- Rail-to-rail input and output
- Low supply voltage: from 2.2 to 5 V
- Low power consumption: 1 mA max. at 5 V
Additional features
- Very high accuracy and stability:
- Offset voltage 25 µV max. at 25 °C, 35 µV over the full temperature range (-40 to 125 °C)
- Low supply voltage: 2.2 – 5.5 V
- Gain bandwidth product: 3 MHz
- Automotive qualification
- Extended temperature range: -40 to 125 °C
- Micro packages: DFN-8 2 x 2, SO-8 and MiniSO-8
- Additional Benefits:
- Higher accuracy without calibration
- Accuracy virtually unaffected by temperature change
more information: https://www.st.com/en/amplifiers-and-comparators/tsz181.html
Login
