![TDK InvenSense ICP-10125 Pressure & Temperature Sensor IC is waterproof TDK InvenSense ICP-10125 Pressure & Temperature Sensor IC is waterproof](https://www.electronics-lab.com/wp-content/uploads/2021/06/115543215.png)
TDK InvenSense ICP-10125 Pressure and Temperature Sensor IC is based on MEMS capacitive technology which provides ultra-low noise at the lowest power. This enables the sensor IC to provide industry-leading relative accuracy, sensor throughput, and temperature stability. This sensor IC can measure pressure differences with an accuracy of ±1Pa. This accuracy enables altitude measurement differentials as small as 8.5cm. The ICP-10125 consumes only 1.3µA at 1Hz and is available in a small footprint 3.55 mm x 3.55 mm x 1.45 mm chimney package with waterproofing gel This gel provides IPx8 waterproofing up to 10ATM. This sensor IC offers an industry-leading temperature coefficient offset of ±0.5Pa/°C and operates within -40°C to 85°C temperature range. Applications include smartwatches, altimeters, and barometers for portable device, home and building automation, and weather forecasting.
- 30kPa to 110kPa pressure operating range
- Noise and current consumption:
- 0.4Pa @ 10.4µA (ULN mode)
- 0.8Pa @ 5.2µA (LN mode)
- 3.2Pa @ 1.3µA (LP mode)
- Pressure sensor relative accuracy:
- ±1Pa for any 10hPa change over 950hPa to 1050hPa @ 25°C
- Pressure sensor absolute accuracy:
- ±1hPa over 950hPa to 1050hPa @ 0°C to 65°C
- Pressure sensor temperature coefficient offset:
- ±0.5Pa/°C over 25°C to 45°C @ 100kPa
- ±0.4C temperature sensor absolute accuracy:
- IPx8 waterproof to 10ATM
- -40°C to 85°C temperature operating range
- I2C host interface at up to 400kHz
- 1.8V ±5% single supply voltage
- RoHS and Green compliant
more information: https://invensense.tdk.com/products/1-axis/icp-10125/
