![TE Connectivity / Holsworthy CJP Aluminum Enclosed Resistors TE Connectivity / Holsworthy CJP Aluminum Enclosed Resistors](https://www.electronics-lab.com/wp-content/uploads/2022/09/CJP400-850x603.png)
TE Connectivity CJP Aluminum Enclosed Resistors are compact high-wattage resistors with power ratings up to 1000W. These resistors feature aluminum enclosures to enable improved reliability and higher operating temperatures up to 450°C. TE Connectivity CJP Aluminum Enclosed Resistors are suitable for a variety of applications, including power supplies, inverters, servo motors, and warehouse automation.
- Large power and size ratio
- Up to 1000W power rating
- ALuminum enclosure enables higher operating temperature
- Vibration resistant
Specifications
- 60-1000W rated power
- 0.2-1.5Ω minimum range
- 20-20kΩ maximum range
- 5% tolerance
- 250°C-450°C maximum surface temperature at rated power
more information: https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+Sheet%7F1773309-8%7FB%7Fpdf%7FEnglish%7FENG_DS_1773309-8_B.pdf%7F2176503-5
Login
