![Temperature Display with NeoPixel Ring Color Temperature Display with NeoPixel Ring Color](https://www.electronics-lab.com/wp-content/uploads/2016/04/3637311436166764209-e1460650708833.png)
This is an OLED temperature display based on ATmega328p along with a NeoPixel led ring to display different colors depending on temperature.
This is a small temperature display using a OLED with a NeoPixel Ring around it using MQTT on a ESP8266 and sending data to the on board ATmega328p. It will cycle on a timer though environmental data from other nodes in the house. The LEDs represents the temperature based on color to give an idea of the temperature in the home or apartment I also added a PIR to turn off the LEDs when no one is around since this is designed to run off a LiPo battery. The core is running DomotiGA (Home automation core) and Mosquitto (MQTT broker). Part of this project is exploring the ESP8266 and learning MQTT.
Temperature Display with NeoPixel Ring Color – [Link]
