![Tesmo – The Invisible & Portable Adhesive Laptop Stand quick review Tesmo – The Invisible & Portable Adhesive Laptop Stand quick review](https://www.electronics-lab.com/wp-content/uploads/2019/09/IMG_0001.jpg)
Tesmo Kickstand weighs only 17g yet able to hold up to 17.6lbs, and the reusable design gives you the mobile convenience than ever.
Tesmo Kickstand is a great little accessory for your laptop, but not limited. It can easily be used on tablets and mobile phones as well. It’s a lightweight and foldable stand that help you use your laptop in an easy and convenient way by adjusting it’s positioning.
![](https://www.electronics-lab.com/wp-content/uploads/2019/09/IMG_0012-e1569862192425.jpg)
With only 0.6 oz(17g), Tesmo Kickstand is the world’s smallest invisible laptop stand. Tesmo Kickstand is strong and durable that can hold up to 17.6lbs of weight. Attaching and removing are both incredibly easy, and it won’t leave any residue on the surface, making it easily the world’ best invisible Laptop Stand.
Thanks to Tesmo Kickstand’s special glue, it’s not only durable and strong, you can also detach and leave no residue on the surface, and re-attach Tesmo Kickstand with the same strong effectiveness.
Usage Video
The Tesmo Kickstand is live on Kickstarter, already funded and has 9 days to go. Pledges start from 15 USD for 1 pair of Tesmo.
CORRECTION 6/10/2019: The pads of Tesmo should be folded to the rear of laptop as shown on the image below to achieve maximum stability. Video shows this the wrong way.
