![Texas Instruments TMP114 Digital Temperature Sensor Texas Instruments TMP114 Digital Temperature Sensor](https://www.electronics-lab.com/wp-content/uploads/2022/02/130909466.png)
Texas Instruments TMP114 Digital Temperature Sensor is a high accuracy, I2C-compatible digital temperature sensor in an ultra-thin (0.15mm) 4-pin package. The small size and low height of the TMP114 optimize volume-constrained systems and enables novel placement of the sensor under other surface mount components for fast and accurate temperature measurement.
The Texas Instruments TMP114 has an accuracy of ±0.3°C and offers an on-chip 16-bit analog-to-digital converter (ADC) that provides a temperature resolution of 0.0078°C. The TMP114 is 100% tested on a production setup that is NIST traceable. The TMP114 is designed to operate from a supply voltage range of 1.08V to 1.98 V, with a low average supply current of less than 0.7µA to maximize battery life.
- High accuracy
- TMP114
- ±0.3°C maximum from –10°C to 85°C
- ±0.5°C maximum from –40°C to 125°C
- TMP114N
- ±1°C maximum from –40°C to 125°C
- TMP114
- –40°C to 125°C operating temperature range
- 16-bit resolution: 0.0078°C (LSB)
- Low power consumption
- 0.7µA average supply current
- 0.16µA shutdown current
- Supply range: 1.08V to 1.98V
- 1.2V compatible logic inputs independent of supply voltage
- I2C and SMBus compatible interface
- 50ns spike filter to coexist on I3C mixed bus
- Optional Cyclic Redundancy Check (CRC)
- 300ms response time
- Adjustable averaging
- Adjustable conversion time and period
- Continuous or one-shot conversion mode
- Temperature alert status with hysteresis
- NIST traceability
- Ultra-thin 4-ball PicoStar (DSBGA) package with 0.15mm height
Block Diagram
more information: https://www.ti.com/product/TMP114
