![Texas Instruments TPS92610-Q1 Automotive Single-Channel LED Drivers Texas Instruments TPS92610-Q1 Automotive Single-Channel LED Drivers](https://www.electronics-lab.com/wp-content/uploads/2020/11/152004013.png)
Texas Instruments TPS92610-Q1 Automotive Single-Channel LED Driver is a simple and ideal solution to deliver constant current for a single LED string with full LED diagnostics. The device operates from an automotive car battery. The TPS92610-Q1 addresses different requirements using the TPS9261x-Q1, TPS9263x-Q1, and TPS9283x-Q1 devices within the one-fails–all-fail feature. The TPS92610-Q1 devices are AEC-Q100 qualified for automotive applications.
- Qualified for Automotive Applications
- AEC-Q100 Qualified With the Following Results:
- Temperature Grade 1: –40°C to 125°C Ambient Operating Temperature Range
- Device HBM ESD Classification Level H2
- Device CDM ESD Classification Level C3B
- Single-Channel Constant-Current LED Driver With PWM Dimming
- Wide Input-Voltage Range: 4.5V-40V
- Operating Junction Temperature Range: –40°C to 150°C
- Constant Output Current, Adjustable by Sense Resistor
- Precision Current Regulation, Tolerance ±4.6% Across Junction Temperature –40°C to 150°C
- Maximum Current: 450mA
- Heat Sharing With External Resistor
- Low Dropout Voltage (Sense–Resistor Voltage Drop Included)
- Maximum Dropout: 150mV at 10mA
- Maximum Dropout: 400mV at 70mA
- Maximum Dropout: 700mV at 150mA
- Maximum Dropout: 1.3V at 300mA
- Diagnostics and Protection
- Single-LED Short-Circuit Detection With Auto-Recovery
- LED Open-Circuit and Short-Circuit Detection With Auto-Recovery
- Diagnostic-Enable With Adjustable Threshold for Low-Dropout Operation
- Fault Bus up to 15 Devices, Configurable As Either One-Fails–All-Fail or Only-Failed-Channel-Off
- Low Quiescent Current and Fault-Mode Current (<250µA per Device)
more information: https://www.ti.com/product/TPS92610-Q1
Login
