![TFT display module features contrast ratio of 900:1 TFT display module features contrast ratio of 900:1](https://www.electronics-lab.com/wp-content/uploads/2021/11/RDS_PR-Image_Tianma-11.6-inch-TM116VDSP02-TFT-LCD.jpg)
The TM116VDSP02 features Full HD (1920 x 1080 pixels) resolution, a 16:9 wide aspect ratio, a high brightness rating, and exceptional optical performance characteristics.
Ideal for use in high ambient light and outdoor environments, the Tianma TM116VDSP02 is manufactured with an anti-glare surface polariser and supports 88° wide viewing angles in all directions (up/down, left/right).
Supporting a brightness specification of 1600cd/m² and a contrast ratio of 900:1, display images are bright, colorful, and concise. The white LED backlight has a 50K hour half brightness lifetime.
Typical applications include graphical user interfaces (GUI) for ticketing systems, information terminals, point-of-sale equipment, marine navigation, and in-vehicle systems.
Justin Coleman, display division manager, RDS said,
“The high brightness Tianma 11.6-inch TFT display module provides a versatile and highly capable display solution for a wide range display applications particularly those where high levels of ambient or outdoor light may be present. Additionally, RDS can offer advice, design-in support and expertise for customers developing display-based products for a wide range of applications and equipment.”
The 11.6inch display module has mechanical outline dimensions of 273.5mm (w) x 166.5mm (h) x 7.8mm (d) and an active display area of 256.3mm (w) x 144.2mm (h).
A wide operating temperature range of -20°C to +80°C enables operation in extreme operating environments.
The 30-pin data interface supports dual-channel 24-bit LVDS and 8-bit RGB color data enabling a color palette of up to 16.7m colors.
Review Display Systems have extensive experience and knowledge designing and developing fully integrated embedded systems utilizing the latest display and embedded computing technology.
The 11.6-inch Tianma TM116VDSP02 TFT display module is now available immediately from Review Display Systems.
Representing leading global manufacturers, RDS supports a comprehensive range of display technologies, touch screen,s and embedded computing solutions.
more information: https://www.tianma.eu
