![The FireBeetle 2 ESP32-C6 IoT Development Board with Wi-Fi 6, Bluetooth 5, Solar-Powered Support The FireBeetle 2 ESP32-C6 IoT Development Board with Wi-Fi 6, Bluetooth 5, Solar-Powered Support](https://www.electronics-lab.com/wp-content/uploads/2024/01/DFR1075.jpg)
The FireBeetle 2 ESP32-C6 is a compact and energy-efficient IoT development board that features the ESP32-C6 microcontroller and supports advanced connectivity options like Wi-Fi 6, Bluetooth 5, Zigbee 3.0, and Thread 1.3. Solar-powered charging and Target Wake Time technology for low power consumption are ideal for smart home automation, air quality, and soil monitoring projects.
The ESP32-C6 is an 802.15.4 baed IoT microcontroller by Espressif Systems. Key features of this module include a single-core 32-bit RISC-V processor, 2.4 GHz WiFi 6, Bluetooth 5.0 LE, and an 802.15.4 radio supporting Zigbee 3.0 and Thread 1.3. The ESP32-C6-DevKitC-1 development board offers an 8MB SPI flash, two USB-C ports, GPIO, UART, SPI, ADC, SDIO, and I2S interfaces, along with an RGB LED. Its device is compatible with ESP-IDF v5.1 for the development environment.
As we mentioned earlier FireBeetle 2 supports Thread 1.3, a protocol designed for low-power, secure, and scalable mesh networking in IoT devices. It features IPv6-based connectivity, and enhanced reliability, and is optimized for smart home and commercial IoT applications.
The FireBeetle 2 ESP32-C6, supporting Wi-Fi 6, enables ultra-low-power IoT devices with efficient operation and low latency. Its Wi-Fi 6 capability, including Target Wake Time technology, reduces power consumption and extends battery life.
The FireBeetle 2 ESP32-C6 features a versatile power system, supporting Type-C, 5V DC, and solar charging for lithium batteries. It includes a solar power management chip with MPPT algorithms for optimal solar panel performance and offers battery-level monitoring for consistent operation.
FireBeetle 2 ESP32-C6 IoT Development Board Specifications:
- Basic Parameters:
- Operating Voltage: 3.3V
- Type-C Input Voltage: 5V DC
- VCC Input Voltage: 5V DC or 4.5-6V Solar Panel
- Max Charging Current: 0.5A
- Sleep Current: 16uA (in deep sleep mode, powered by battery)
- Operating Temperature: -10~60℃
- Dimensions: 25.4x60mm / 1×2.36”
- Hardware Information:
- Processor: RISC-V single-core, 160 MHz
- Memory:
- SRAM: 512KB
- ROM: 320KB
- Flash: 4MB
- RTC SRAM: 16KB
- USB: USB 2.0 CDC
- Wi-Fi:
- Protocols: IEEE 802.11b/g/n, IEEE 802.11ax (20 MHz-only non-AP mode)
- Bandwidth: Supports 20 MHz and 40 MHz at 2.4 GHz
- Modes: Station, SoftAP, SoftAP+Station
- Frequency: 2.4GHz
- Frame Aggregation: TX/RX A-MPDU, TX/RX A-MSDU
- Bluetooth:
- Protocol: Bluetooth 5, Bluetooth mesh
- Frequency: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
- IEEE 802.15.4:
- Compatibility: IEEE 802.15.4-2015 protocol
- Frequency Band: 2.4GHz
- Data Rate: 250Kbps
- Supports: Thread 1.3 and Zigbee 3.0
- Ports and Interfaces:
- Digital I/O: 19x
- LED PWM: 6 Channel
- SPI: 1x
- UART: 3x (LP UART x1)
- I2C: 2x (LP I2C x1)
- I2S: 1x
- IR Transceiver: 5x transmit channel, 5x receive channel
- ADC: 1x 12-bit SAR, 7 Channel
- DMA Controller: 3x transmit channel, 3x receive channel
The FireBeetle 2 ESP32 C6 Microcontroller includes comprehensive documentation including a product wiki, the ESP32-C6 chip datasheet, schematics, and dimension details. The shipping list for this product includes one FireBeetle 2 Board ESP32 C6 Microcontroller and two sets of 20-pin 2.54mm pin headers. There are also some tutorials available on the robot product page.
The FireBeetle 2 ESP32 C6 IoT Development Board can be purchased directly from DFrobot or you can buy it from Aliexpress. In both outlets, it is priced at $5.90.
