![The industrial ACPL-K308U photovoltaic driver is designed to drive high voltage MOSFETs The industrial ACPL-K308U photovoltaic driver is designed to drive high voltage MOSFETs](https://www.electronics-lab.com/wp-content/uploads/2021/04/BroadcomACPL-K308U.jpg)
The industrial ACPL-K308U photovoltaic driver is designed to drive high voltage MOSFETs. It consists of an AlGaAs infrared light-emitting diode (LED) input stage optically coupled to an output detector circuit. The detector consists of a high-speed photovoltaic diode array and a turn-off circuit. This photovoltaic driver turns on (contact closes) with a minimum input current of 5 mA through the input LED. It turns off (contact opens) with an input voltage of 0.8 V or less. The ACPL-K308U is ideal for the fast turn ON/OFF in inrush current prevention and Insulation resistance measurement/leakage current detection.
Key features
- 8 mm creepage and clearance in a compact SSO8 package
- Operating temperature range: -40 °C to +125 °C
- Photovoltaic driver for high voltage MOSFETs in Solid State Relay (SSR) applications
- Typical switching speed: 0.058 ms (TON), 0.016 ms (TOFF) at IF = 10 mA, CL = 1 nF
Additional features
- Open circuit voltage:
- 8.2 V (typ) at IF = 10 mA
- Short circuit current:
- 60 µA (typ) at IF = 10mA
- Logic circuit compatibility
- Configurable to a wide portfolio of high voltage MOSFETs
- Galvanic isolation
- High input-to-output insulation voltage
- Safety and regulatory approvals:
- IEC/EN/DIN EN 60747-5-5
- Maximum working insulation voltage VIORM = 1140 VPEAK
- 5000 VRMS for 1 minute per UL
- Stretched SO-8 package outline footprint:
- 8 mm (min) clearance/creepage
more information: https://www.broadcom.com/products/optocouplers/industrial-plastic/other/solid-state-relay/acpl-k308u-000e
Login
