The Pi5 Connector supports Raspberry Pi5 and Pi4B
1.149
Transmission of audio and visual signals without distortion plays a significant role in communication and electronic systems. While efficient devices are required for such transmission,  the interfacing of the development board is not achieved easily. For this purpose, connector adapter boards are being used, and the “new” Pi 5 adapter board, which is compatible with Raspberry Pi 5 / 4B, converts the video and audio signal from micro HDMI to HDMI without significant loss of quality.
Key Features:
  • Compatible with both the latest version of Raspberry Pi-5 as well as  Raspberry Pi-4B.
  • Requires a 2x power supply method in operation.
  • Via USB  type-C pin.
  • Screw terminal configuration pin.
  • Ultimately gives dual 4k resolution outputs.
  • Performs as  µ-HDMI to HDMI  multifunctional adapter
  • Conventionally connects the HDMI ports : Converts Micro HDMI Interfaces To HDMI Female Ports For Easier Connection.
The PI-5 connector adapter supports both the versions of Raspberry-Pi-5  as well as Pi-4B. Both the microprocessors contain the same pin configuration and circuit architecture which makes the connector board compatible with each developing module at specific working operations. This essentially makes it easier to interface between devices with different HDMI port sizes. It gives a 4k HD resolution display at the output end. The adapter enables a conversion of micro HDMI to HDMI. This little adapter turns the Raspberry Pi’s mini HDMI output into a conventional HDMI connector, enabling smooth interaction with HDMI cables often used in home entertainment installations and presentations. The Raspberry Pi 5 can display clear and vibrant content on digital signs through its HDMI connection, which supports high-definition video output. It can connect easily to many types of displays commonly used in digital signage setups because HDMI is widely compatible across different display devices.
Raspberry Pi devices are known for their flexibility in handling content. They can run various operating systems like Ubuntu, Raspberry Pi OS (formerly Raspbian), and specialized software designed for digital signs. This allows users to schedule displays, remotely edit and manage content, and customize signs according to their requirements.
Specifications of the Pi-5 Connector:
  • The base board contains a 2x HDMI interfacing pins
  • A type-C for power supply pin
  • Two  USB type-B dual 4k output pins
  • A single type –C for output interfacing
  • 5V screw terminal port
  • Outline dimensions: 85 mm x 33.5 mm
  • A 3PIN cable 100mm  and a 3PIN squid cable 100mm
Overall, the micro HDMI to HDMI adapter for Raspberry Pi offers a simple yet effective solution for extending the display capabilities of your Raspberry Pi, facilitating seamless connectivity with HDMI-equipped devices for enhanced productivity, entertainment, and creativity. You can refer to their page for more information about the product and purchase-related queries.
Saumitra Jagdale is a Backend Developer, Freelance Technical Author, Global AI Ambassador (SwissCognitive), Open-source Contributor in Python projects, Leader of Tensorflow Community India, and Passionate AI/ML Enthusiast
view all posts by saumitra
