The Universal Serial Bus, commonly known as USB, is probably one of the smartest innovations of today. In this digital era, a USB extension cable plays an important part in businesses as most of our devices would be of no use without them. USB extension cables are used to access, gather, and transfer data to be easy.
Moreover, there are times when compatible devices, like printer, scanners, and other office equipment, have shorter cables making the connection ports inaccessible. USB extension cables are extremely useful in such situations.
Let us take a look at the power of USB extension cables in detail.
Faster data transfer
Higher data transfer rates allow business networks to perform all their complex tasks. For larger and heavier tasks such as online streaming, using USB extension cables could help you improve the performance of your business’s own network.
USB extension cables can carry information at about 12 Mb per second when compared to ordinary parallel cables that can only transfer 115 Kb per second.
Multiple connections
USB extension cables are made for multitasking and you can connect multiple devices unlike when you use a parallel cable. USB hubs allow you to connect multiple devices at the same time without you to be worrying about any decline in the performance.
Charge your devices
How many times have you faced a situation where you had power but wanted to charge your phone quickly without using a wall socket? One powerful advantage of a USB extension cable is that they can be used to charge gadgets like mobile phones and tablets.
What about a situation where there is no power at all? You can use a USB extension cable to draw electricity from your laptop or portable power bank, or even your car’s lighter socket.
Data transfer without an internet connection
If you have ever been in a situation where you needed to transfer a few files but you didn’t have Internet access, you know how powerful a USB extension cable can be. The solution is to attach your gadget to a laptop using a USB extension cable then transfers the files.
Reduces data fluctuation
Data fluctuation due to low internet speed can be an issue when you have to transfer data in bulk. However, USB extension cables are powerful enough to transfer large amounts of data at high speeds without any fluctuations.
Draw power for devices
Other than charging gadgets like phones and tablets, a USB extension cable can be connected to USB-powered devices.
USB extension cables are a significant part of any business set up as they guarantee data transmission and also assist in charging electronic devices and make it easier to connect your computer with other devices.
USB extension cables are accessible and are available in a variety of sizes, shapes, capacities, IP ratings and colours for various purposes. USB extension cables are durable and last longer than a standard parallel cable.
Looking for a USB extension cable to power any device, charge your gadgets or transfer data? Check out our wide-ranging list of affordable cables on our website.
Great informative post. Thank you.
Valuable tips! Well, the particulars for a USB 1.0 and 2.0 standard downstream port, convey up to 500 mA or 0.5A. I found it very helpful for all. Thanks and keep sharing.
