![ThingPulse Pendrive S3 – A ESP32-S3 Pendrive with RGB LED, Wireless Storage and Much More ThingPulse Pendrive S3 – A ESP32-S3 Pendrive with RGB LED, Wireless Storage and Much More](https://www.electronics-lab.com/wp-content/uploads/2024/06/PendriveS3_PCB_Top-2-e1719232785872.jpg)
![](https://www.electronics-lab.com/wp-content/uploads/2024/06/ThingPulse.png)
Though it’s called a Pendrive, the ThingPulse Pendrive S3 is not your average drive it’s a versatile device that can transform into various USB gadgets, like a memory stick, keyboard, mouse, or even a networking tool. But its most intriguing use? It can be a “BadUSB” with the SuperWifiDuck software, and at this point, we all know what a USB Rubber Ducky can do!
The module is built around The Espressif ESP32-S3-MINI-1 module which features an Xtensa dual-core 32-bit LX7 core with 2.4GHz Wi-Fi and Bluetooth 5 (low-energy). Previously we have written about many different ESP32-S3-based products including Waveshare ESP32-S3-Matrix Dev Board, Waveshare ESP32-S3-Tiny Board, Unexpected Maker Nano S3, and much more, feel free to check those out if you are interested in the topic.
The ESP32-S3 Pendrive S3 incorporates a hidden capacitive touch button, activated by touching the device’s casing. This design choice preserves the device’s sleek appearance. The innovative use of a spring for this button is detailed in Dani Eichhorn’s article.
The ESP32-S3 Pendrive S3 can be used as a hacking tool. It can inject scripts onto a computer, allowing remote control by simulating keystrokes. The SuperWifiDuck software enhances this by enabling wireless script management through a web interface. Other potential applications include a memory stick with cloud sync, a Wi-Fi dongle, and a password manager.
The ESP32-S3 Pendrive S3 leverages the open-source TinyUSB stack to emulate various USB devices like keyboards, mice, storage drives, and more. It is compatible with CircuitPython, making it user-friendly for programming enthusiasts. Similar USB stick devices include the Waveshare RP2040-GEEK, T-Dongle ESP32-S2, and Overdrive USB.
ThingPulse Pendrive S3 Specifications
- Wireless Module: ESP32-S3-MINI
- CPU: Dual-core Xtensa LX7 @ 240 MHz
- Wireless: 2.4GHz Wi-Fi and Bluetooth 5 (LE)
- Memory/Storage:
- 512 KB SRAM
- 8 MB on-chip flash
- 128 MB flash memory (addressable via SDIO/MMC or SD card interface, in 1-bit or 4-bit mode)
- Enclosure: USB stick plastic enclosure
- Interfaces:
- USB-C male connector
- Features:
- Capacitive touch button (spring-based, not visible externally)
- WS2812B addressable RGB LED
- USB Functionality:
- Uses TinyUSB open-source USB stack
- Emulates multiple device classes:
- Human Interface Devices (mice, keyboards)
- Mass Storage
- Video
- Network
- Development Support:
- Compatible with CircuitPython
- Applications:
- Can function as a BadUSB device for hacking and penetration testing
- Supports keystroke injection attacks with SuperWiFiDuck
- Scripts can be managed wirelessly via the web interface
- Other Potential Uses:
- Memory stick with cloud sync capabilities
- Wi-Fi dongle
- Password manager functionality
The ESP32-S3 Pendrive S3 has multiple uses. It can act as a hacking tool (BadUSB) to inject keystrokes and remotely control computers, with scripts managed wirelessly through SuperWifiDuck. Additionally, it can serve as a regular memory stick with cloud sync, a Wi-Fi adapter, or even a password manager.
ThingPulse Pendrive S3 is priced at around $25 and can be purchased from the ThingPulse website. While not flawless, it’s suitable for hobbyists and experimentation.
