![The third revision of the Raspberry Pi can best be summed up by the old adage of more of the same. The third revision of the Raspberry Pi can best be summed up by the old adage of more of the same.](https://www.electronics-lab.com/wp-content/uploads/2018/03/Raspberry-Pi-3B-1024x686.jpg)
The third revision of the Raspberry Pi can best be summed up by the old adage of more of the same. A faster processor and Power over Ethernet capability were advertised – OEMsecrets tells you what you need to know.
Raspberry Pi’s are always sold via the ecosystem. This is a promise which the foundation, by and large, manages to keep: if you use a sufficiently recent version of RaspBian so that the new SOC is supported, the same memory card can also be used in older versions of the process computer. When looking at the thing from the top, not many differences can be seen. The most important change is the addition of the four pin header for the Power over Ethernet hat: it might cause problems with some cases. Other than that, the physical dimensions remain the same.
The third revision of the Raspberry Pi can best be summed up by the old adage of more of the same – [Link]
