Engineer and designer Vincent "CentyVin" has designed a simplified USB-C PD (Power Delivery) based PPS (Programmable Power Supply) trigger board, that allows users to easily set different output voltages by simply using a potentiometer.
USB-PD-Trigger-SuperCharged-with-PPS.jpg - Electronics-Lab.com
99
This PD Trigger Board Features a Potentiometer - Adjust Output Voltage
Engineer and designer Vincent "CentyVin" has designed a simplified USB-C PD (Power Delivery) based PPS (Programmable Power Supply) trigger board, that allows users to easily set different output voltages by simply using a potentiometer. CentyVin in his Hackday Post Explains that this board is A ... Read More
About Debashis Das
view all posts by das
