TickTagOpenSource is an Open-Source GPS Logger for Wildlife Tracking
Built on an open-source sentiment, TickTagOpenSource is a versatile GPS tracker featuring customizable hardware and user-friendly firmware. Complementing these features is an intuitive Android app, accompanied by detailed assembly guides and numerous other resources.
In wildlife research and conservation, GPS trackers are essential, But the problem is, that commercial GPS trackers are often expensive, and their complex features aren’t always necessary for basic tracking. That’s why TickTagOpenSource is so valuable. It’s a DIY GPS tracker designed for tracking and monitoring wildlife. Being open-source, it’s freely available for anyone to use and customize. when I checked out the GitHub Repo The project provides everything you need easy-to-follow instructions for building the tracker, user-friendly software for its operation, and even designs for a 3D-printed case.
Taking a look at the Hardwear side of things, the Rev3 and Rev4 PCBs for the TickTagOpenSource are built with Autodesk Eagle 9.5.2. So if you are an Eagle user it’s very easy for you to modify the schematic and PCB according to your needs. With Such flexibility, you can be certain that the logger is well-equipped to handle the diverse challenges of wildlife tracking.
The TickTagOpenSource project also features easy-to-use software. The logger runs on firmware written in C/C++, allowing for straightforward flashing using Arduino or Atmel-ICE. This makes it easy for nontech-savvy people who are new to this field.
The open-source nature of this project makes it very easy for users to assemble their GPS trackers. All that users need to do is solder batteries, attach them to the terminals, and place the entire assembly inside the enclosure. The project also provides clear instructions and how to operate their trackers safely in various weather conditions. This allows people to utilize advanced technology with minimal difficulty.
For data storage, the project utilizes a lossless compression algorithm. As a result, you can collect a substantial amount of information without the need for frequent downloads. It’s also straightforward to download, reset, and configure the tracker, with the data output in a user-friendly CSV format that’s easy to work with.
Another cool part is that it includes designs (STL files) for 3D-printed cases. This creates a protective cover for the tracker, which makes it durable and useful out in the field.
Unique Features of  TickTagOpenSource :
  • Detailed guides for both hardware production and software programming.
  • Customizable design catering to various tracking needs.
  • Emphasis on community involvement and feedback.
For more details, including access to the project’s resources, visit the TickTagOpenSource repository on GitHub.
About Debashis Das
view all posts by das
