![Tiniest USB development board with Micronucleus Tiniest USB development board with Micronucleus](https://www.electronics-lab.com/wp-content/uploads/2019/08/2019-07-23T03-05-53.045Z-IMG_0412.jpg)
Development board for the ATtiny84a with USB connector. Pre-loaded with the Micronucleus bootloader compatible with Arduino.
DIP version with USB connector of the ATtiny84a. The board can be placed in the middle of the breadboard. Sketches can be uploaded from Arduino using the Micronucleus bootloader. There is an indicator LED to determine if the board is in bootloader mode. The push button is connected to the interrupt pin (INT0) and can be used to wake up the board when used in low power applications where sleep mode is required.
Tiniest USB development board with Micronucleus is available on Tindie.com for $4.90
Login
