![Tiny Machine-Code Monitor Tiny Machine-Code Monitor](https://www.electronics-lab.com/wp-content/uploads/2018/07/machinecodemonitor.jpg)
This project is a machine-code monitor that you program from a hexadecimal keypad using a simplified instruction set. by David Johnson-Davies
It’s a good project for learning about the fundamentals of machine code, and will also appeal to people who like programming challenges. The simplified machine code, called MINIL, is designed to be easy to learn and understand. It’s similar to the Little Minion Computer [1] used in some universities to teach students about machine code. The same method could be used to emulate other simple processors, such as the SC/MP, 6800, 8080, or 6502.
Tiny Machine-Code Monitor – [Link]
Login
