![Toshiba TCK207AN Load Switch IC Toshiba TCK207AN Load Switch IC](https://www.electronics-lab.com/wp-content/uploads/2022/02/189834390.png)
Toshiba TCK207AN Load Switch IC offers a 0.75V ultra-low voltage with a slew rate control driver and reverses the current blocking (SW OFF state) function. The TCK207AN is ideal for power management and portable applications that require high-density board assembly such as SSD, HDD, cellular phone.
The Toshiba TCK207AN Load Switch IC supports a switch ON resistance of only 21.5mΩ (typ.) at 0.75V, -1.5A condition, and output current is available up to 2.0A (DC).
The TCK207AN is housed in a DFN4A (1.2mm x 1.2mm, t:0.38mm) ultra-small package.
- VIN = 0.75V to 3.6V Low input voltage operation
- IOUT (DC) = 2.0A High output current
- Low ON resistance :
- RON = 21.5mΩ (typ.) at VIN = 3.3V, -1.5A
- RON = 21.5mΩ (typ.) at VIN = 1.2V, -1.5A
- RON = 21.5mΩ (typ.) at VIN = 0.75V, -1.5A
- Built in Slew rate control driver
- Built in Reverse current blocking (SW OFF state)
- Built in Auto-discharge
- Active High and Pulldown connection between CONTROL and GND
- DFN4A (1.2mm x 1.2mm, t: 0.38mm) Ultra-small package
Block Diagram
Login
