![TPS25750 – Highly integrated USB Type-C® and USB PD controller with pre-configured GUI TPS25750 – Highly integrated USB Type-C® and USB PD controller with pre-configured GUI](https://www.electronics-lab.com/wp-content/uploads/2021/06/TPS25750-USB-Type-C-PD-Controller-TI-Mouser.png)
Texas Instruments TPS25750 USB Type-C & Power Delivery (PD) Controller is optimized for applications supporting USB-C PD Power. The TPS25750 integrates fully managed power paths with robust protection for a complete USB-C PD solution. The Texas Instruments TPS25750 also integrates control for external battery charger ICs for added ease of use and reduced time to market. The intuitive web-based graphical user interface (GUI) will ask the user a few simple questions on the application’s needs using clear block diagrams and simple multiple-choice questions. As a result, the GUI will create the configuration image for the user’s application, reducing much of the complexity associated with competitive USB PD solutions.
- Integrated fully managed power paths
- Integrated 5V, 3A, 36mΩ sourcing switch (TPS25750S/D)
- Integrated 28V, 7A, 16mΩ bi-directional load switch (TPS25750D only)
- Standalone USB Type-C PD solution
- No firmware development or external micro-controller needed
- Integrated robust power path protection
- Integrated reverse current protection, overvoltage protection, and slew rate control the high-voltage bi-directional power path
- Integrated undervoltage and overvoltage protection and current limiting for inrush current protection for the 5V/3A source power path
- 26V tolerant CC pins for robust protection when connected to non-compliant devices
- Optimized for power applications
- Integrated I2C control for TI battery chargers
- Web-based GUI and pre-configured firmware
- Optimized for power consumer only (sink) (UFP) applications
- Optimized for power provider (source) and power consumer (sink) (DRP) applications
- SB Type-C power delivery (PD) controller ten configurable GPIOs
- BC1.2 charging support
- USB PD 3.0 compliant
- USB Type-C specification complaint
- Cable attach and orientation detection
- Integrated VCONN switch
- Physical layer and policy engine
- 3.3V LDO output for dead battery support
- Power supply from 3.3V or VBUS source
Reference Design
more information: https://www.ti.com/product/TPS25750
