![TPSM82810 – 2.75-V to 6-V, 4-A step-down module with adjustable-frequency & tracking TPSM82810 – 2.75-V to 6-V, 4-A step-down module with adjustable-frequency & tracking](https://www.electronics-lab.com/wp-content/uploads/2021/01/TPSM82810-Step-File-E2E.png-1230x0-1.png)
TPSM8281x is a family of pin-to-pin 3-A and 4-A compatible high efficiency and easy to use synchronous step-down DC/DC power modules with integrated inductors. They are based on a fixed-frequency peak current-mode control topology. They are used in telecommunication, test and measurement, and medical applications with high power density and ease of use requirements. Low resistance switches allow up to 4-A continuous output current at high ambient temperatures. The switching frequency is externally adjustable from 1.8 MHz to 4 MHz and can also be synchronized to an external clock in the same frequency range. In PFM/PWM mode, the TPSM8281x automatically enters Power Save Mode at light loads to maintain high efficiency across the whole load range. The TPSM8281x provides a 1% output voltage accuracy in PWM mode which helps design a power supply with high output voltage accuracy. The SS/TR pin sets the start-up time or tracks the output voltage to an external source. This allows external sequencing of different supply rails and limits the inrush current during start-up.
Features for the TPSM82810
- Input voltage range: 2.75 V to 6 V
- Output voltage range: 0.6 V to 5.5 V
- Adjustable and synchronizable switching frequency of 1.8 MHz to 4 MHz
- Spread spectrum clocking – optional
- Selectable forced PWM or PFM/PWM operation
- Output voltage accuracy ±1% (PWM operation)
- Power-good output with window comparator
- 100% duty cycle
- Output discharge
- Precise ENABLE input allows
- User-defined undervoltage lockout
- Exact sequencing
- 15-µA typical quiescent current
- Adjustable soft-start or tracking
more information: https://www.ti.com/product/TPSM82810
