Turing Pi 2.5: A Mini-ITX Cluster Board for Raspberry Pi CM4 and Nvidia Jetson with AI Accelerators
1.096
The Turing Pi 2.5 is a modular, energy-efficient mini-ITX cluster board designed for building compact, noiseless server clusters. It supports up to 128GB of RAM and allows users to mix and match system-on-modules like Turing RK1, Raspberry Pi CM4, and Nvidia Jetson for general computing and AI tasks. A built-in Ethernet switch features a 1 GbE L2 switch with VLAN support, multiple SATA and M.2 ports, USB 3.0, PCIe slots, HDMI, and a GPIO compatible with Raspberry Pi.
The Turing Pi 2.5 is ideal for home labs, self-hosting, cloud-native applications (such as Kubernetes), and machine-learning projects. Users can extend its capabilities with third-party hardware modules like Wi-Fi, Bluetooth, 4G/5G, and various sensors, making it highly adaptable for data center-style setups in a smaller, quieter form.  It’s a great choice for developers and hobbyists needing flexible and scalable computing power because it is identical to Turning Pi 2.
Previously, we have written about similar cluster boards like the Turning Pi’s 7-slot Raspberry Pi CM3, the Deskpi SUPER6C Raspberry Pi CM4 Mini-ITX Board 6, the Risc-V Cluster from Milk-V supports Jupiter NX and Megrez NX module, and much more. Feel free to check those out if you are interested in the topic.
Turing Pi 2.5 Mini-ITX Cluster Board Layout
Turing Pi 2.5 Mini-ITX Cluster Board Specifications:
  • SoC compatibility:
    • Turing RK1: Rockchip RK3588, 8 cores, up to 32GB RAM, NPU
    • Raspberry Pi CM4: Broadcom BCM2711, 4 cores, up to 8GB RAM
    • Nvidia Jetson modules (various for AI/ML tasks)
  • Networking:
    • 1x GbE L2 switch with VLAN support
    • 2x 1 GbE ports
  • Storage interfaces:
    • 2x SATA III ports 6 Gbps
    • 4x M.2 slots (2260, 2280, Key-M) with NVMe support
  • Ports:
    • 2x Mini PCI Express slots
    • 1x HDMI
    • 1x DSI display interface
    • 1x 40-pin GPIO (Raspberry Pi compatible)
    • SIM card slot for cellular connectivity
    • RTC battery slot
  • USB:
    • 4x USB 3.0 ports
    • 1x USB 2.0 port
  • Power supply:
    • 24-pin ATX power connector
    • Energy-efficient, consume less than 80W
  • Miscellaneous:
    • Baseboard management controller
    • Supports Wi-Fi, Bluetooth, and 4G/5G through extension modules
    • Mix and match compute modules (Turing RK1, Raspberry Pi CM4, Nvidia Jetson)
  • Form factor:
    • Mini ITX board for compact setups
Additionally, the new Turing Pi mini-ITX case, measuring 240 x 240 x 100 mm, is made of aluminum and designed for the Turing Pi 2 and 2.5 boards. It has magnetic lids for easy module and accessory swaps, supports up to three 2.5-inch HDDs, and can be powered by a Flex ATX PSU or Pico PSU with an external power brick. More details are available on Turning Pi’s separate announcement page.
You can get the Turing Pi 2.5, a mini ITX Cluster Board from Turning Pi’s product page at $259.00.  As for the Turing Mini-ITX case, you can get it at $129.00.
About Sayantan Nandy
view all posts by sayantan
