![TV Tuner IR remote with a PIC16F684 TV Tuner IR remote with a PIC16F684](https://www.electronics-lab.com/wp-content/uploads/2016/07/DSC_0425.png)
Tahmid built a TV tuner IR remote with a PIC16F684:
I then proceeded to write an IR transmitter using the PIC16F684 (using the MPLAB X IDE and XC8 compiler), following the timing information from the extended NEC protocol. In order to connect all the keys, I connected them in matrix keypad form.
In order to power the remote off 2xAA batteries, it is necessary to use sleep mode – otherwise the battery will be drained extremely quickly. So, in order to detect when a button is pressed, an interrupt is used. After the IR command is sent, the microcontroller goes to sleep. The interrupt wakes up the microcontroller when a button is pressed. Debouncing is achieved using simple software delays. When a button is held down, the NEC command repeat sequence is not sent. Instead, the remote relies on releasing the button and pressing it again.
TV Tuner IR remote with a PIC16F684 – [Link]
