![Understanding Relay Coil Voltage Specifications Understanding Relay Coil Voltage Specifications](https://www.electronics-lab.com/wp-content/uploads/2018/04/edf445078b208f71e49611707457e68c11db728d_1_690x197.png)
When learning about relays there are a couple coil voltage specifications that can be a little tricky to understand. There are typically 4 specification for coil voltage listed in the datasheet. For this example we will be looking at relay part Z2352-ND 14. This is a SPST non-latching relay with 1 Form A (normally open) set of contacts.
Understanding Relay Coil Voltage Specifications – [Link]
Login
