![Upcoming Orange Pi Pro to Feature K3588S Chipset with LPDDR5 RAM and PoE+ support Upcoming Orange Pi Pro to Feature K3588S Chipset with LPDDR5 RAM and PoE+ support](https://www.electronics-lab.com/wp-content/uploads/2024/04/Orange-Pi-Pro-e1712760464304.jpg)
In a recent announcement, orange has recently announced some key details about their latest Orange Pi 5 Pro SBC. From that, we know this new board will be built around the RK3588S SoC and It will have a GbE port with PoE+ support, M.2 Key slot for expansion, and Wi-Fi5/BT5.0 connectivity 6 TOPS NPU 16GB of LPDDR5 eMMC 5V/5A DC
The RK3588S SoC features a quad-core Cortex-A76 CPU (up to 2.4GHz) and a quad-core Cortex-A55 CPU (up to 1.8GHz), alongside an ARM Mali-G610 quad-core GPU (up to 1GHz) and a 6-TOPS NPU for enhanced AI capabilities.
The RK3588S is the latest and greatest SoC that Radex has to offer, and this is not the first board to utilize this SoC. Previously, the ROCK 5C used this SoC to power their SBC, and the trend is likely to continue.
The SoC also features a Mali-G610 GPU, along with a 6 TOPS NPU. On top of that, It supports LPDDR5 RAM options (4GB, 8GB, or 16GB) and versatile storage including eMMC, MicroSD, and M.2 slots. Supporting HDMI 2.1 for 8K at 60Hz and HDMI 2.0 for 4K at 60Hz, it also features DP1.4 ALT. With MIPI 4-Lane for high-res video, ES8388 codec for audio, and a 40-pin GPIO header, it’s a flexible, multimedia-centric board.
Upgraded Orange Pi Pro Specifications
- SOC: Rockchip RK3588S (8nm LP process)
- CPU: 8-core 64-bit processor utilizing big.LITTLE architecture with four Cortex-A76 cores at 2.4GHz and four Cortex-A55 cores at 1.8GHz
- GPU: Arm Mali-G610, supports OpenGL ES 1.1/2.0/3.2, OpenCL 2.2, and Vulkan 1.2
- NPU: Embedded with up to 6 TOPS computing power, supports INT4/INT8/INT16 mixed operations
- PMU: RK806-1
- Memory:
- RAM: LPDDR5 (496PIN) options: 4GB, 8GB, 16GB
- Storage Options: eMMC socket (optional), SPI Flash (default empty), MicroSD (TF) slot
- Expansion: M.2 M-KEY slot for NVMe or SATA SSD
- Connectivity:
- USB Ports: USB3.1 Gen1 x1, USB2.0 x1, USB2.0 HUB (TYPE A x2 + row of pins x2)
- Video Output: HDMI 2.1 (up to 8K @ 60Hz), HDMI 2.0 (up to 4K @ 60Hz), MIPI DSI 4 Lane (up to 4K @ 60Hz)
- Camera Interface: Dual MIPI 4-Lane
- Audio: CODEC ES8388, 3.5mm jack, onboard MIC, HDMI 2.1 eARC
- Ethernet: 10/100/1000Mbps with PoE+ support (additional HAT required)
- Wireless: Wi-Fi 5 + Bluetooth 5.0/BLE (AP6256 module)
- Expansion Ports:
- PCIe: M.2 M-KEY Socket supports NVMe or SATA SSD
- General Purpose: 40Pin dual-row pin, supports UART, PWM, I2C, SPI, CAN, GPIO
- Power Outputs: Supports DC 5V and 3.3V from the expansion port
- Other Features:
- Buttons: MaskROM, RESET, POWER
- Indicators: RGB LED tri-color
- Cooling: 5V 2PIN 1.25mm fan socket
- Real-Time Clock: 3V 2PIN 1.25mm socket
- Debugging: UART via 40PIN expansion port
- Supported Operating Systems:
- Orangepi OS (Droid), Orangepi OS (Arch), Ubuntu, Debian, Android 12
- Physical Specs:
- Dimensions: 89mm x 56mm x 1.6mm
- Weight: 62g
- Power Supply: Type-C, 5V @ 5A
The Orange Pi RK3588S board offers multiple Orange Pi OS variants including OH, Arch, and Droid OpenWRT for network projects, mainstream Linux distributions like Ubuntu and Debian, and an Android image for graphical applications. Additionally, the Linux source code is available for custom development, accommodating a wide range of use cases and developer needs.
At the time of writing orange Pi has not disclosed the pricing for any variants of these boards yet. For further details, please visit the product page.
